Accessing Mass Fraction Values and Plotting using TUI
Like Tree1Likes
  • 1 Post By ankur_kr
Old   July 31, 2013, 01:34
Default Accessing Mass Fraction Values and Plotting using TUI
Ankur
ankur_kr is on a distinguished road
I need to run my fluent-simulation in batch mode. I want to write a script to automatically run the simulation and save a plot of Mass-fraction of CO vs Y-axis coordinate as .jpg file. Before writing the shell script I wanted to see the sequence of text commands I need to execute.
So, I tried the /plot>plot... commands but I couldn't find how to access the mass fraction values in the TUI. Also this command only ends up writing the .XY file rather than plotting it on the screen. [ If the plot gets displayed on the screen, I could then use the /display>save-picture command to save the .jpg file ].
Using a macro could have been an option but I don't find an option to activate the macro at the end of computation (only options available were to specify certain time-steps or iterations).
Please help,
Ankur
ankur_kr is offline   Reply With Quote
Old   August 6, 2013, 20:44
Default solution to above problem
Ankur
(for others who might face the same problem)
To access mass fraction of CO via TUI, I typed: solution co
My batch script file
/file/read-case rc1.cas
/file/read-data rc1.dat
/display/set/rendering-options
driver
null
q
/plot
plot-direction
0
-1
0
solution co
yes
11
q
/display
save-picture
/exit yes
Originally Posted by ankur_kr View Post
Please help,
Ankur
Dri likes this.
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
plotting volume fraction Falak. Siddiqui FLUENT 0 March 13, 2006 00:32
Plotting raw data values Wilesco Siemens 0 January 5, 2006 05:34
