August 14, 2013, 14:15 |
Help!! Minimum PDF table temperature read
Clan McKenzie
Rep Power: 12 |
Hello Everyone!
I desperately need assistance with the following problem. I have been trying to do combustion analysis for a couple of months now and have a repeating problem. During the solution portion of the simulation on FLUENT 13.0 I have the following read out on each time step... "Minimum PDF table temperature in 9893 cells on zone 3" The number of cells fluctuates greatly. I have a video of each step that I have done at the link below. https://www.youtube.com/watch?v=-CDNB22fWFo I have tried increasing the mesh, increasing the fuel and oxid temperatures without any results DISREGARD THE FLOW RATES IN THE VIDEO! I have corrected them and they are not connected to the error. THANK YOU IN ADVANCE! |
August 15, 2013, 01:47 |
Graham
The text interface (tui) that you showed looks like species transport and not non-premixed or partially-premixed. With the non-adiabatic non-premixed model, you should have an option called non-premixed-combustion-expert and the heat loss parameter is in there. Once you lower it, you have to re-generate the pdf table. Note that with just a few cells hitting the min table temp, you can really ignore this - it will only have a really small effect on the solution. g |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
High temperature methane+air | Peter | FLUENT | 5 | January 26, 2009 19:04 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
Read table | chris1980 | OpenFOAM Running, Solving & CFD | 1 | August 31, 2006 04:32 |
Ist it only me that cant read the user guide pdf | olle53 | OpenFOAM | 5 | April 5, 2006 23:14 |
