January 28, 2011, 14:17 |
GENERATE MESH IN ICEM and OPEN IN FLUENT 12
Engr Adeniyi
Rep Power: 16 |
Hi guys,
Can someone please explain, line by line as much as possible, with a very simple geometry like Rectangle, how to (1) Create a Mesh in ICEM 12 and Generate .msh file (2) Open the Mesh in Fluent 12 I have read a number of voluminous tutorials that are not organised in one location. After creating my mesh it saves as .uns and Fluent will not read it. When I tried using Fluent_V6 as the solver and I generated a .msh file, Fluent will crash while reading it with errors like : Error: Build_Grid: no cells in case file and at times no zone or cannot read file. This is really frustrating... |
January 31, 2011, 11:28 |
RE: GENERATE MESH IN ICEM and OPEN IN FLUENT 12
Engr Adeniyi
Rep Power: 16 |
TUTORIAL FILE:
http://cobweb.ecn.purdue.edu/~aerody...romScratch.pdf The tutorial above leads to the "how" but I don't still get why my system is giving this error: When Run as 3D > Reading "C:\My Documents\CFD\FLUENT\TUTORIALS\fluent.msh"... 1200 nodes. 1131 quadrilateral wall faces, zone 9. Building... mesh Error: Build_Grid: no cells in case file. Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error. Error Object: #f When Run in 2D Error: Error reading "C:\My Documents\CFD\FLUENT\TUTORIALS\fluent.msh". Error Object: #f Reading "C:\My Documents\CFD\FLUENT\TUTORIALS\fluent.msh"... 1200 nodes. 1131 quadrilateral cells, zone 9. 2194 2D interior faces, zone 10. Building... mesh Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f Last edited by Galileo; January 31, 2011 at 11:31. Reason: Wrong path, using the second one instead |
February 3, 2011, 10:38 |
Resolved Reading ICEM 12.1 Mesh in Fluent 12.1
Engr Adeniyi
Rep Power: 16 |
Thanks guys for trying to help me.
I was able to figure that I was not associating the "edges to the respective curves" properly, when that was done I was able to read in Fluent. The error displayed in Fluent was not good for a beginner and was misleading ACCESS_VIOLATION error. |
February 3, 2011, 16:46 |
Simon Pereira
Rep Power: 47 |
Exactly right. In ICEM CFD Hexa, only edges associated to curves generate line elements. These line elements form the boundaries for 2D meshes. These boundaries are critical and the Fluent solver can not run without them.
You must associate all the perimeter edges with the perimeter curves, even if they are straight and the edges already seem aligned. Sorry about the error message. Usually it gives a "null pointer" error. |
April 11, 2011, 05:05 |
Same problem
Phani
Rep Power: 15 |
Hey galileo,
I'm new to ICEM CFD. I'm facing the same problem, I read the tutorial that u have posted but i haven not come up with any solution. I have tried in many ways to load the msh file that is created by icem. Can u please let me know how to do it? I have to submit my report in 10 days. |
April 11, 2011, 05:08 |
Same Issue
Phani
Rep Power: 15 |
Hey Galileo,
can u let me know how to associate curves to edges ? |
April 11, 2011, 13:39 |
Simple Tutorial -To Get Some Results
#7 | |
Engr Adeniyi
Rep Power: 16 |
If you can follow this simple tutorial, I hope it will help. Assume you are drawing a dam _____Top____ |***** *****| |***** *****| |***** *****| |Wall1***** *|Wall2 |***** *****| |****# *****| |***** *****| |____bottom__| (@GEOMETRY TAB) Specify the points and join the lines and create the parts as appropriate. On the position # (anywhere inside the fluid domain) create a body named Fluid (eg) (@BLOCKING TAB) -Click Create Block (First item) -In the DEZ part name=Fluid -Type (This is a 2D Blocking, select 2D Blocking) -Apply (All visible) -Now Click Split Block and Split by click the Edge and split into the blocks that suits your case...Apply (this case does not need it) - No Click Associate (item number 5) on Blocking Tab -In the DEZ click second item ie Associate Edge -Select Edge then Click Middle Button of your Mouse then Select the Curve and the Middle button of the mouse (Repeat this for all the edges) _______________Edge _____Top____ |***** *****| | |***** *****| |Edge Wall |***** *****| | |Wall1** ****|Wall2 |***** *****| | |***** *****| | |***** *****| | |____bottom__| | _______________Edge bottom e.g Click Edge Wall then Middle mouse and Click Curve Top, Then Click Edge wall then Curve Wall2 etc (Edge will be red curve will turn black) You can redo each curve to edge if you are not sure (without need to undo) Now proceed to 9th item (Pre-Mesh Param) Go to item 3 on the DEZ select the edge and put the number of nodes and apply (repeat for other edges -default is 2) ...in this case you need to select only Wall1/2 and Top/Bottom not the 4 ...you will notice that. You now have your mesh set up. Expand the Blocking Tree and click Pre-Mesh Right-Click on the Pre-Mesh and Click -CONVERT TO UNSTRUCTURED MESH Now Click OUTPUT TAB Red Box: DEZ: Select Solver: Ansys and Fluent 6 BC: Select your BC SAVE: Remember to Click 2D (for this 2D case) The default file name is fluent (you can change it to myfirstdam) The file saves to myfirstdam.msh You can open it in Fluent 6 or 12 or 13. Enjoy and hope it helps |
April 20, 2011, 02:02 |
3D meshing
Phani
Rep Power: 15 |
hey Galileo,
thanks for the advice. i was able to load cylinder into fluent. but i wish to load a mesh with little irregular geometry. i have attached the geometry.. i have not been able to create a perfect mesh for it.. maybe its because i'm not doing the blocking well.. please advice!! |
April 20, 2011, 19:43 |
#9 |
Simon Pereira
Rep Power: 47 |
This is a basic Y pipe configuration... There are many ways to do it.
If the flow splits, then the best way is very similar to the pipe blade tutorial (just half of it). That tutorial will show you how to collapse blocks to make this configuration. You could also do it with a T configuration (as is done for the 2D mixing pipe tutorial). Optionally, you could create an actual Triangular YBlock (all hexa) in the middle, with radiating blocks... It is pretty straight forward but I don't think we have a tutorial for that. Best regards, Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
April 22, 2011, 08:31 |
tried but not working!
#10 |
Phani
Rep Power: 15 |
hey simon,
thanks for the advise. but unfortunately i haven't been able to do as u suggested. the mesh that is getting created is not cylindrical as in figure and instead is polygonal and i cannot define the inlet and the outlet. can u suggest any other way to create geometry and then do the blocking as i'm guessing that the problem is geometry. phani |
September 6, 2013, 14:26 |
#11 |
hi Galileo,
I am stuck with this single element problem in ICEM. My geometry is a 3D IGES file. I imported and mesh it using the Delaunay scheme. The single elements error pops up when I check the mesh. Is there a way to get around this. I have attached the picture. Thank you very much. |
Display Modes | |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Export 2D mesh from ICEM to Fluent | enghamed | ANSYS Meshing & Geometry | 18 | August 10, 2015 21:49 |
Export 2D mesh from ICEM to Fluent | BuilttoSpill | ANSYS Meshing & Geometry | 4 | August 28, 2010 09:16 |
ICEM Edit Mesh | blackbody | ANSYS Meshing & Geometry | 3 | March 8, 2010 03:49 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
