v2f model - periodic boundaries - turbulent viscosity limited to viscosity ratio
Old   September 13, 2013, 10:05
Default k-omega SST vs V2-f
Davide
Davide_sd is on a distinguished road
Hi all,
i'm trying to compare the performace of k-omega SST vs V2f. I'm simulating an hill.
this is the geometry of the simulation: link
profile at inlet should be such that the flow is in fully developed state. The paper provide me only the velocity profile.
To get the other profiles, i've setup a simulation of a flat terrain with periodic boundary conditions, as explained to me in this thread.
Residuals of the simulation with k-omega SST, for flat terrain (these are good): image
Residuals of the simulation with V2f, for flat terrain (these aren't good): image
As you can see the residuals tend to be periodic... After 350K iterations the periodic-pattern was still the same...
Using the profiles of k, omega,... obtained from simulations above, and the velocity profiles from the paper, i'll get these results: Result of hill simulations
I was expecting the k-omega SST to overstimate the recirculation region; this is the reason i have tryed the V2F. Anyway, i was also expecting the V2F to give better result in respect to k-omega SST; i was wrong...
What can i do to improve the result of V2F?
PS:
1 - all flat terrain simulations have: y+ < 1.
2 - y+ for hill simulations: image
3 - the Reynolds number should be < 4772.
Davide_sd is offline   Reply With Quote
Old   September 14, 2013, 11:53
Davide
bump, i've changed the subject of the thread...
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
"turbulent viscosity limited to viscosity ratio" olivier FLUENT 11 October 10, 2015 05:49
turbulent viscosity limited to viscosity ratio Alex_B FLUENT 16 September 12, 2012 13:17
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
