filling and draining of tank
1 Attachment(s)
Hi dear friends
I want to simulate filling and draining of tank. I get bad results. results in compare with exact solution(bernoli equation) are wrong. I have doubt in boundary conditions. pressure inlet: gauge pressure is equal to 0 pressure outlet: gauge pressure is equal to 0 operating pressure is equal to 101325pa I attache a screenshot of my geometry an BCs. Please help me in this case. Best Regards Jamal |
are u using VOF model? |
Thank you so much
I want to simulate only single phase and fluid flow. |
your problem is in equilibrium because there isn't any pressure difference in domain.
both inlet and outlet pressure is 0 only gravity could be the cause of draining the tank. if your fluid is air, this parameter is negligible. |
Fluid is water. I dont know how determine mass flow inlet or velocity inlet, if I know this, I set these BCs. Can you help me in this case? |
This looks like something you could solve with ODEs, rather than with FLUENT. Exactly what are you trying to calculate?
