June 8, 2013, 07:20 |
Pressure waves
Hello everyone, iam trying to create a detonation wave iam using single step reaction mechanism, though many journals say that reduced chemical kinetics mechanism should be used to create detonation. I just want to give a try with single step. I created a high pressure and temperature zone and a zone of gaseous h2o. Here i used explicit type. Initially the combustion reached a pressure of 141atm and velocity was about 1800m/s ans temp was about 4220k. Gradually the pressure and temp reduced to 58atm and 3750k after 5500 iterations. I have attached the picture of the pressure front formed can anyone say me whether the reaction trying to form detonation front or not. Iam a beginner in fluent.
June 9, 2013, 10:11 |
yaaaaay i got the detonation front.... Atlast iam done with my project..
June 19, 2013, 12:32 |
Some pics of the detonation front.. Pressure, mach and temp
September 23, 2013, 10:04 |
Rep Power: 12 |
dear ganuganu, i am doing the similar hydrogen detonation simulation, i use the finite-rate/eddy-disspation model, but the pressure shock i got is very low, and the velocity is also very low. i am very interested in your models and some parameters. I will thank you very much for your help
September 23, 2013, 11:35 |
#5 | |
September 23, 2013, 22:30 |
Rep Power: 12 |
thanks.you mean the laminar finite rate model is suitable for the detonation.i also want to know the explicit type is set in the solution methods?
Display Modes | |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
b.c., how to exterminate undesired pressure waves? | simpson | OpenFOAM Pre-Processing | 1 | April 15, 2019 07:56 |
Getting the pressure waves in Fluent for a water hammer problem | teopetre | FLUENT | 2 | August 6, 2013 20:24 |
What is the approach to modeling pressure waves from a vibrating surface? | czechman45 | Main CFD Forum | 2 | March 21, 2012 23:36 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 15:32 |
