June 17, 2008, 02:22 |
Refrigerator simulation
Dear all,
I am simulating the air flow inside the refrigerator. Actually I dont want to include the evaporator. Instead of evaporator, I have created the separate fluid zone. Is it possible to give the temperature loss when the air goes through this evaporator fluid zone. How to give input in fluent? Thanks in advance, with regards, JSM |
June 17, 2008, 05:06 |
Re: Refrigerator simulation
What about refrigerant? Is it air which is pasing through the evaporator?
If you know net heat transferred then you may choose to apply Heat Flux BC over the wall of your evaporator domain. I have never done such analysis but just it is my idea. |
June 18, 2008, 08:22 |
Thanks for reply. |
November 18, 2012, 03:01 |
condensor analysis
ok
hi,
i am doing analysis of condenser coil in fluent.the inlet condition are vapor at 100 deg celsius and velocity o.2m/s and at coil wall convection h= 10 w/mk ,phases are (primary) vapor and(sec) water,which model is suits better mixture or eulerian pls can any body suggest me |
April 22, 2014, 14:14 |
help me
Raifmohammed@gmail.com
Assume we want to simulate certain properties of a refrigerator, namely:
capability to maintain maximum inside temperature up to a given maximum outside temperature energy consumption Which systems/subsystems/components properties have to be simulated? |
no-frost refrigerator | ozgur | CFX | 2 | August 6, 2008 20:11 |
i want advise( In case Refrigerator ) | brown, choi | Main CFD Forum | 1 | October 1, 1998 18:04 |
i want advise( In case Refrigerator ) | brown, choi | Main CFD Forum | 0 | October 1, 1998 02:59 |
