mesh refinement worse results
Old   September 10, 2013, 10:29
Unhappy mesh refinement worse results
Silvia Calderón
Silvia CT is on a distinguished road
Send a message via MSN to Silvia CT
Dear all
I'm simulating a tube with wall
at uniform temperature, very simple I know. I got a Nusselt of 3.65..etc, close enough (almost 3.66, as in the literature), the problem is: as I refine the mesh Nu decreases and I don't know what is wrong, any ideas??
Saludos.
Silvia
Best Regards
Silvia CT is offline   Reply With Quote
Old   September 12, 2013, 09:15
Gonzalo
gfoam is on a distinguished road
Hi, first I will ask you for some details:
1) What kind of mesh are you using?
2) What kind of refinements are you doing?
3) What turbulence models are you using?
4) Is it a steady or unsteady simulation?
5) Your residuals converges (goes down enough) in all the meshes you are using?
6) Did you construct a BL mesh for you tube?
Regards
PD: Regards=Saludos
gfoam is offline   Reply With Quote
Old   September 12, 2013, 09:34
Silvia Calderón
Lots of questions!! :P
I'm using the axisymmetric model, so I have to mesh a simple rectangle (only quadrilateral mesh elements).
I'm simulating steady and laminar flow and I'm utilizing an UDF at the inlet (fully developed flow) so the refinements are made only in the "y" direction (is that correct?)
I used a size function in the y axis.
Saludos!=regards
Silvia
Best Regards
Old   September 12, 2013, 13:24
Gonzalo
Be careful with the quality of the mesh. Try to keep the aspect ratio between razonable values (under 1000 or less). I don´t know wich is the 'y' direction in your model, may be if you post an image of your mesh, I will realize that. One sugestion, if you refine your mesh in the radial direction, you have to refine in the angular an axial direstions too.
Old   September 24, 2013, 11:55
Silvia Calderón
This is the simplest mesh I'm working with, I still don't know what I'm doing wrong
Silvia
Best Regards
Old   September 24, 2013, 14:42
Gonzalo
Mmm, it's strage. May be you could do some contour plots of temperature and/or velocity of the solution in the different meshes you're using. May be you can find somthing strange in the behavior of the the flow that is causing these errors in your simulations. But one thing that I know, is that if you refine the mesh, given certain BC's, you will resolve structures of the flow that you didn't before with your coarse meshes and you will tend to the exact solution for such BC's. Another thing that I sugest you is to plot the Nusselt number vs the size of the mesh an see if you get a monotonic behavior or not. Regards
Gonzalo
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
