velocity inlet and ideal gas simultaneously-what's wrong?
Old   September 28, 2013, 04:51
Default velocity inlet and ideal gas simultaneously-what's wrong?
preetam
preetam69 is on a distinguished road
hi all,
i am running simulation for a pipe flow with heat transfer. to validate my results i need to use dittus-boelter correlation which is only applicable for fully developed turbulent flows. so i need a fully developed profile at inlet, for which i am using profiles from the outlet for the same to get the developed flow.
but i also need to consider compressiblity effects,so i have to use idael gas for for density specification.
now for compressible flows ideal inlet boundary conditions are mass flow inlet and pressure inlet , so using velocity inlet is questionable.
so to sum it up,
what is wrong in using velocity inlet bc at inlet while considering ideal gas for density specification?
or
how can i ensure fully developed flow at inlet if i use mass flow inlet or pressure inlet boundary conditions?
help me guys...stuck here.
thnx in advance...
preetam69 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
