Error: failed in parallel
Old   September 27, 2013, 15:37
Default Error: failed in parallel
Claudio
cdgatti is on a distinguished road
Hello
I have a mesh of 7,000,000 elements created in Gambit. When read in Fluent, parallel version, throws me the following error:
Error: failed in parallel_build_grid
Primitive Error at node ..... : Null domain pointer
To solve this problem, first I read the mesh in Fluent serial version, configure the simulation, initialize with FMG, save the .cas and .dat. Then I opened the Fluent parallel version, read on .cas and .dat and perform the iterations. In some models this way solved the above problem, however in other models, what happens to me is that when I run the iterations in the parallel version, I just used a core of eight that has my computer! therefore takes a very long time! and I'm not taking advantage of the CPU. When all goes well, the simulation converges in three hours, the other way, it takes days!
Someone out where you can be the problem?? or to fix it?
Thank you very much in advance for your answers.
Best regards
Claudio
cdgatti is offline   Reply With Quote
fluent, gambit
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 15:25
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 11:30
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
