Cold FLow analysis in Gas Turbine..Help Needed
Old   May 18, 2012, 06:45
Post Cold FLow analysis in Gas Turbine..Help Needed
juzer_700 is on a distinguished road
I have been trying to use ANSYS FLUENT Software to simulate cold flow analysis inside a combustion chamber. But I am having difficulties. It shows reverse flow when I run the calculation. My geometry is in 2D-Axisymmetrical. Also I have taken a swirl facter of 0.7 using K-Epsilon RNG turbulence method.
Inlet condition:
Velocity- 1m/s, Air at 600K
Pressure Outlet - Gauge pressure=0
Is the reverse flow because I have included the swirl in the flow? Or is it because my domain is small?
I would really appreciate if you can help me figure out the problem. Thanks in advance.
juzer_700 is offline   Reply With Quote
Old   May 23, 2012, 04:18
James Willie
jwillie2000 is on a distinguished road
Hi, I think it is because of the swirl in the flow. I would suggest you activate the radial equilibrium pressure distribution option at the outlet and allow sufficient time for it to run and see whether the reverse flow would go away. Good luck! Jimmy
jwillie2000 is offline   Reply With Quote
Old   May 23, 2012, 05:18
Yogesh Patil
foamcfd is on a distinguished road
It could be physical because of the swirl. Try extending your doamin at outlet. I won't worry if it's physical though.
foamcfd is offline   Reply With Quote
Old   May 23, 2012, 06:28
@foamcd @jwillie2000
Thanks for replying
I extended the domain. And also activated the radial equilibrium pressure. Although the reversed flow has reduced, but there are still one or two points where it's occuring. I think it's physical as you pointed out.
Old   August 17, 2013, 11:11
JAY
JAY ADHVARYU is on a distinguished road
How i get mean quatity plot in fluent like mean pressure plot, mean stremline plot etc.
JAY ADHVARYU is offline   Reply With Quote
Old   August 17, 2013, 13:52
James Willie
You have to monitored the quantities you are referring to. Normally u would do it in a plane if it is a 3D problem and you can take the area weighted average of the said quantity and then do the plot after. Are u running unsteady simulation? I would assume yes. In case you want to know what is happening along the centerline you can also export the data if you define your centerline. Once the data is exported as ASCII data you can do the plot using any plotting program.
You need to be more specific about what you want to do in case my post doesn't answer your question.
Old   August 24, 2013, 09:42
JAY
I have some problem with my boundary condition that how i utilize the neumann condition(∂φ/∂x = 0) at outlet. Can i select pressure outlet at outlet?
my inlet condition is :
flat velocity profile =40m/s
Re=1.916*10^5
turbulent intensity=4.5%
And Inlet height of duct=5mm
I select velocity inlet at inlet because my flow is incompresible.
And axis boundary condition applied along the centerline.
and no slip condition at wall.
pls help me.
Old   September 10, 2013, 05:03
raymond350 is on a distinguished road
Your inlet velocity is just 1m/s? If you increase it to say 30 or 40m/s i believe you will have lesser or no reverse flow.
raymond350 is offline   Reply With Quote
Old   September 30, 2013, 02:47
JAY
yes, my flow is fully developed if you able to help pls help me as fast as possible because if i use pressure outlet at outlet i got reverse flow.
combustion chamber, fluent 13.0, gas turbine, non premixed combustion
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
CFD Analysis - Combustion in Gas Turbine Engine juzer_700 Main CFD Forum 0 April 19, 2012 02:10
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
how to set up high temperature gas turbine flow simulation? adam2008 CFX 1 July 22, 2009 18:33
flow in gas turbine Abdul Hafid Main CFD Forum 1 September 14, 1998 09:39
