October 1, 2013, 15:00 |
Sliding Meshing
Damien Geslain
Rep Power: 12 |
Hi all,
I am working on a "vortex induced vibrations" model. Actually I have two beams which are vibrating beside each other in the X direction. I am simulating this model in ansys fluent as a 2D model with : -1 velocity inlet -2 plates -2 boundary layer called 'moving_fluid' (Hybrid meshing which is moving with my plate) -1 enclosure called "fluid" I have written a UDF for the dynamic meshing which is working perfectly for 1 plate and let the displacement of my beams on the X (longitudinal) direction with a stiffness 'k' However as soon as I try to simulate my model with 2 plates, 2 different issues appear : 1/ If I let a space between my two 'moving_fluid' zones, it will be too small and the dynamic meshing cannot work for some velocities 2/ If I want to bond my 2 'Moving_fluid' zones and create a sliding mesh (look at the following picture), I have an overlapping issue which appears because I give the same name to two different entities.. I have no idea how I can resolve this issue. I want my two plates moving independently from each other but for the moment it is impossible.. I am stuck on that problem for 2 days now so I would really appreciate if somebody could help me with that. Is there any tutorial ? Thanks for helping, Damien |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
Sliding meshes and meshing | Joel | Siemens | 0 | September 9, 2002 06:35 |
