How to set two inlet boundary condition???Plz help
Old   February 20, 2007, 03:42
Default How to set two inlet boundary condition???Plz help
asghari
Hi all;
I have two inlet boundary condition, pressures and velocities in inlet have a specified value;For example : Pin1=10barg,Vin1=10m/s. Pin2=05barg,Vin2=05m/s.
How to adjust fluent setting for this case? Should I use a UDF for this case? have you an example or a tutorial like as this case?
Thanks in advance for any help.
Old   October 17, 2013, 13:45
Default 2 inlet
Nazim
shahid nadeem is on a distinguished road
hello
i dont think we can apply two inlet conditions, atleast i have not used it. however if you get to know about it then tell me too
shahid nadeem is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 07:44
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
transitional inlet boundary condition kamp CFX 1 June 21, 2006 11:08
