May 28, 2013, 10:13 |
Wood combustion initialization--help needed
Roderick
I am almost completely new to Fluent, but my Master's thesis is centered around constructing a CFD model for biomass (wood) combustion in a small cookstove. I am attempting to model said combustion using Species Transport while injecting "Combusting" Discrete Phase wood particles. However, I cannot seem to figure out how to achieve ignition without creating unrealistic boundary conditions for the application. Once combustion is begun I believe that my model can sustain it to steady-state; however, without setting a very high thermal wall boundary condition (which I would rather not do, as wall temperature is an output of interest) or constructing some high-temperature or heat-generating smaller volume (which I would rather not do, as it affects the outlet pollutant mass fractions and the feed rate of the fuel), I cannot seem to achieve combustion. Is there a way to initialize combustion in Fluent when attempting a steady-state simulation of this sort?
A relatively comprehensive bulleted list of my set-up:
I believe that's it...I would sincerely appreciate any guidance or assistance that anyone could offer. As I'm said, I'm a complete rookie at Fluent and CFD in general, so I'm aware of my glaring inexperience. Thanks in advance. |
July 25, 2013, 09:07 |
Sorry, I don't have the answer to your question, I have a question of your kind almost;I am simulating a soaking pit furnace, used for reheating slabs in steel production route. I am not sure if I can use this "mixed thermal boundary condition" while working with furnaces, loaded with ingots (B.C of ingots' surface)... may I ask if you are using 'mixed' thermal boundary condition for the exterior walls, from inside? like you are considering it as the effect of heat transfer of combustion on the surface of walls? how sure you are of picking such a BC? I've been told that I can not use it since its inside the domain,..
October 28, 2013, 16:14 |
Hi Roderik
Bahram
Rep Power: 12 |
I think that u can use patch option after your initializing.I think that patch option let u to increase your temp for a moment.
combustion, ignition, wood |
Wood Devolatilation and Volatile combustion | nutow | FLUENT | 3 | May 3, 2020 23:52 |
combustion of wood shavings | Özer AYDIN | FLUENT | 0 | September 16, 2008 05:40 |
Simple approach - solid wood combustion (newbie..) | Dan | Main CFD Forum | 0 | December 3, 2007 02:06 |
combustion of wood | Özer AYDIN | FLUENT | 4 | June 25, 2007 03:11 |
wood shaving combustion | Özer AYDIN | FLUENT | 0 | November 23, 2006 06:52 |
