Parallel processing problem ("cores")
Old   October 29, 2013, 07:05
Default Parallel processing problem ("cores")
Claudio
cdgatti is on a distinguished road
Working in parallel with the 6.3.26 version of Fluent-t8, with a mesh of 7,000,000 elements, read the mesh and perform the setting of the simulation correctly, but to make the run (iterations) do not work the 8 cores and takes so much!
Someone pass the same? to that is the error?
I hope their views
Thank you very much
cdgatti is offline   Reply With Quote
Old   October 29, 2013, 08:39
FHydro
flow_CH is on a distinguished road
It maybe you are not using parallel processing. try this: right click on fluent desktop icon, on the fluent path add -tn (n=no of processor in CPU, e.g. -t2). for my computer it's
C:\Fluent.Inc\ntbin\ntx86\fluent.exe -r6.3.26 2d -t3
you should insert this address
C:\Fluent.Inc\ntbin\ntx86\fluent.exe -r6.3.26 2d -t8
If you are modeling 3d insert 3d
flow_CH is offline   Reply With Quote
Old   October 29, 2013, 08:41
Paritosh Vasava
vasava will become famous soon enough
Do you have academic license? Those have restrictions about number of nodes you could use.
Are you using any UDF?
vasava is offline   Reply With Quote
Old   October 29, 2013, 08:54
Claudio
Thanks for the reply flow_CH.
Now I have the commands as you propose: C: \ Fluent.Inc \ ntbin \ win64 \ fluent.exe 3d-t8-r6.3.26
In fact, I made ​​the partition in 8 correctly, starts with FMG perfect, but when iterating cores do not work.
Any other ideas?
Old   October 29, 2013, 08:56
Claudio
Vasava: not an academic license should not have size limitation problem and do not use a UDF.
In addition, some upper size models working properly.
Any other ideas?
Old   October 29, 2013, 09:04
Claudio
The model is of a complete vehicle, with ground and rolling wheels. It has two "porous volumes" that model the radiators.
Problem running OpenFOAM 2.2.x in parallel in Centos 5 lvalvare OpenFOAM Running, Solving & CFD 33 December 9, 2020 08:44
Temperature Problem in Parallel Processing pdp.aero SU2 9 July 27, 2014 22:11
[mesh manipulation] Problem with RenumberMesh in parallel in OpenFOAM 2.1.1 srini_esi OpenFOAM Meshing & Mesh Conversion 1 November 8, 2013 02:48
problem with parallel processing keng FLUENT 4 June 14, 2013 23:34
problem parallel processing (meshSearch, openMPI) FabienF OpenFOAM 0 September 10, 2012 04:23
