Fluent warning Hexahedral or polyhedral cell problems |
November 3, 2013, 09:44 |
le hoang anh
Rep Power: 13 |
Hi everyone,
I try to make structure mesh for my model (nozzle). I make quadrangle cell for nozzle hole and mapped face meshing for my model like picture below. But when I ran and check the mesh in Fluent, it warning that: WARNING: The mesh contains high aspect ratio hexahedral or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. Could you help me to fix this problem, I did not find /solve/initialize/repair-wall-distance they said to repaired the mesh. Furthermore, could you suggest me how to make quadrangle for the region in red circle! |
November 6, 2013, 01:49 |
vidyanand
Rep Power: 17 |
DID GET GET ANY WARNING IN QUALITY CHECK?
If you get wraning in qulaity check then you have highly skewed cells in the doiman ,so those cell you can convert to ploy |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? | randomid | OpenFOAM Community Contributions | 1 | August 27, 2010 05:15 |
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit | coompressor | OpenFOAM Installation | 0 | November 12, 2008 19:53 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 13:38 |
