November 8, 2013, 07:00 |
Animation problem
Francisco
Rep Power: 15 |
Hi everybody,
I'm working on a 3d moving mesh and I would like to create some animations. I've tried setting some simulations in Calculation Activities. I've chosen the contours I want to capture and set the storage type as Metafile (.hmf). When I finish my simulation I go to Results/Graphics and Animations and choose Scene Animation/Set up. However I cannot read the animation files I have generated. Which is my error? I know some people just record images and then put them together with a differenet software. Which is the best way to get an animation? Is there another procedure in fluent? |
November 8, 2013, 08:33 |
Tarjei
Rep Power: 12 |
When you say that you "cannot read the animation files [you] have generated", what do you mean? Does Fluent return an error message? In a previous thread, I described problems regarding animating a three-dimensional iso-surface, which I couldn't find a built-in capability of in Fluent. (This is the thread.) I have a feeling you're trying to do something different, but hopefully it helps. Good luck. Tarjei |
November 8, 2013, 12:23 |
#3 | ||
Francisco
Rep Power: 15 |
Now I'm trying the same procedure but instead of metafiles as the file type I've chosen PPM image. Maybe with that I can choose them to get the sequence. I'll post my results. Thanks a lot Tarjei! |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Animation Problem | Salehi | FLUENT | 5 | June 2, 2007 05:30 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
