Node values are explicitly defined or obtained by weighted averaging of the cell data. Various boundary conditions impose values of field variables at the domain boundaries, so grid node values on these boundary zones are obtained by simple averaging of the adjacent boundary face data. In addition, for several variables (e.g., node coordinates) explicit node values are available at all nodes.
By the way we do not have any entrainment of air or tearing off of liquid. It would be better if you would like to sharpen the interphase to geo-reconstruct. The free surface is still at 0,5. |
You should see more definite water and air phases. Can you post here the 2 contour plots with and without node values?
1 Attachment(s)
Let me say this problem another way.
My flow depth in experiments is 1.5 meters. I have flow depth=1.5 meters in fluent too (from volume fraction 1 to 0.5). Then OK. But from volume fraction 0.5 to 0, the distance is about 1 meter! I mean the difference between VF=0.5 to VF=0 is very large. (about 1 meter) What is reason of this problem? Thanks |
Do you mean with your flow Depth the film thickness?
1 Attachment(s)
Please see attached image
1 Attachment(s)
Decreasing the cell size should also decrease the distance between VF=0.5 and VF=0 |
Thank you flutus1
I have very large issue. I modeled this simulation for 5 times. I have just 2 month for my thesis and i can not decrease mesh. For sketching air concentration (void fraction), can i equivalent VF=0 with VF=0.5 since this modeling is true and problem is just from meshing? |
Try to make a dynamic adaption starting from this solution and use compressive scheme (which is more quicker and more stable than geo-recon). The adaption should occur by means of the gradient of VOF.
Or you can refine your mesh only in the vicinity of the free surface since you now approximately when it sets in. Interpolate the old results in the new one. I do not like to comment your intention to assume VOF= 0,5 to be zero... |
Thanks.
1- What is dynamic adaption? 2- With increasing mesh by refining, The time for iterating will be too long. In the present (without refining), the time for iterating of my model is about 26 hours (number of elements is: 1 600 000 elements). Then if i refine the mesh and with 5 simulation, i think i need 2 weeks for iterating (just for a mesh). :( 3-Why you do not like to comment about assuming VF=0 to VF=0.5? Because i thing my problem is just about meshing and there is no other issue. :confused: |
Is there more to this simulation than you have shown by now? To me it looks like quite a simple flow and I dont see where you put those 1.6 million cells.
