July 5, 2010, 08:10 |
How can I convert GUI journal to TUI journal
Harry
Rep Power: 17 |
Hi All,
Through fluent windows interface, I can readily record a GUI journal. How can convert this journal to TUI journal that required in a batch simulation in linux? I would appreciate your suggestions. Best regards, Harry |
July 5, 2010, 11:31 |
Harry
Rep Power: 17 |
Or how can I utilize windows to setup fluent case file on linux
July 6, 2010, 03:14 |
Maxime Perelli
Rep Power: 41 |
you can create a journal file from Fluent:
before setting your case, go to file/write/start journal... Then set up your case, once you are finished, go to file/write/stop journal... Fluent should write everything you did in a journal file, which you can now read... hope it helps
In memory of my friend Hervé: CFD engineer & freerider |
July 6, 2010, 03:18 |
Harry
Rep Power: 17 |
I can only use TUI model in linux. So a GUI journal is not working.
December 4, 2013, 14:48 |
Rep Power: 12 |
BUMP!
I'm having the same problem. I need to generate some results pretty quick. I've only 2 cases to run, but they're too big for my local computer so I have to use a Linux HPC cluster in Batch mode. Creating a GUI journal file is easy - File>Write>Start Journal......."set boundary conditons etc etc"....File>Write>Stop Journal Does anyone know how to turn this GUI journal file into one which can be used in the TUI? |
December 4, 2013, 15:02 |
Rep Power: 17 |
check the cx commands and try to translate manually to native TUI commands
December 4, 2013, 16:50 |
Rep Power: 12 |
If I set FLUENT up and Initialise the solution using the GUI, then save the case and data. Can I then, in my journal file, just read in the case and data and solve? Do I need to set materials and boundary conditions, add materials etc using the TUI?
December 4, 2013, 17:28 |
Rep Power: 17 |
1-yes.
2-No. From self trying one learn much faster.. |
Display Modes | |
TUI Commands from GUI? | Carlos | FLUENT | 6 | May 22, 2013 19:05 |
journal not work without GUI? | sophie | FLUENT | 20 | October 17, 2006 04:32 |
combine Scheme and TUI possible in Fluent Journal? | Qian Zhen | FLUENT | 0 | November 11, 2005 23:54 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 24, 2001 00:16 |
