Tecplot error (using fluent results)
Like Tree1Likes
  • 1 Post By Bean
Old   February 7, 2006, 22:18
Default Tecplot error (using fluent results)
into
When I used Fluent results, I got an error in Tecplot. I exported some results for Tecplot in Fluent, and I tried to load those data in Tecplot.
Err: Not enough elements in Connectivity list Error occurred on line 6909 near position marked with "@" below: 4301 4428 4427 4374@
need help.
Old   February 8, 2006, 02:56
Default Re: Tecplot error (using fluent results)
Tania
hi, You can directly import the case and data files in tecplot. You don't need to convert your results to tecplot format.
Old   February 8, 2006, 10:25
Bean
Hi - I have the same problem with exporting data from Fluent v.6.2 into Tecplot v.9. I get the exact same error message. I know you can directly import data files in Tecplot, as Tania suggests, but my models are quite large and this becomes a very long process. All I want to do is import a single plane. Any suggestions?
Old   February 8, 2006, 11:26
Luca
Unfortunately I have your same prob for tecplot 10.0 as well. You can decide what to load in tecplot panel. I have a problem when I use the coupled solver because no data is referred to surfaces but to the centroids of the cell. So when I want to plot a contour for a wall I get a uniform contour. For the segregated all OK. Any idea? Luca
Old   February 8, 2006, 14:11
Tania
I did a test in two different versions of Fluent.
1- I have fluent files (V6.1.22). I exported data on a single plane to tecplot format. I could read them without any problem in tecplot V10.
2- I exported data on a single plane in Fluent V6.2.16 (using the same fluent files) but I couldn't read them in Tecplot V10.
Old   February 8, 2006, 14:53
into
Thanks guys.
As Tania said, is it fluent version problem? I also use fluent V6.1.16.
Because of the huge file size of results, I can't directly import the case and data files in tecplot. Any good idea?
Old   February 8, 2006, 16:27
Bean
I did the same two tests as Tania but with Tecplot v.9 and found the same results - no problems with Fluent v.6.1.22, but Fluent v.6.2.16 generated an error in Tecplot.
It would seem to me that it is a problem with the latest version of Fluent. I checked the Fluent website to see if there were any known issues with Tecplot, but I was unable to find anything. I wonder if Fluent is aware of the problem???
Old   February 8, 2006, 17:11
Tang
If you compare the 6.1 tecplot file to a 6.2 I believe that in 6.1 it creates where the @ is at in the 6.1 file it will say TRIANGLE and in 6.2 it says QUADRILATERAL. When I change my 6.2 file to say TRIANGLE it loads in ok.
Old   February 9, 2006, 10:03
Bean
Unlike Tang, regardless of whether I export from either Fluent v.6.1 or v.6.2, I get QUADRILATERAL. However, I tried changing QUADRILATERAL to TRIANGLE in the file exported from Fluent v.6.2, and surprisingly, I didn't receive an error message when loading it into Tecplot. Unfortunately Tecplot did not generate the plane properly though - there were holes, or large areas of missing cells, in the mesh.
Old   February 9, 2006, 11:58
Bean
The problem, in my case, lies in the connectivity list. I have been attempting to export a plane with both quadrilateral and triangular cells. Obviously, for quadrilateral cells, there are four node points, and for triangular cells there are three. For Tecplot to be able to read a combination of the two types of cells, the zone type must be set to QUADRILATERAL and there must be four node points listed for all cells - even triangular. In order to fulfill the four node point requirement, the last node point is simply repeated. You can read more on this on PG 72-73 (4.3 - Finite Element Data) of the Tecplot manual. What the new version of Fluent fails to do, is repeat this last node point for triangular cells, and hence, Tecplot cannot read the file. I simply brought the file created in Fluent into Excel, and added the missing node points. It's a pain, but it fixed my problem. Hopefully it will help with your problems too.
dexter likes this.
Old   January 9, 2014, 08:56
Andrey Yakovchuk
einandr is on a distinguished road
Some more notes how the replace trick works, it could be helpful. I had hybrid 3D mesh with both hexahedral and tetrahedral cells. Different data planes were exported for transient solution postprocessing, resulting in 3 zones types:
1)planar zones with quadrilateral faces only
2)planar zones with triangle faces only
3)zones with mixed faces.
In my case I exported all 3 zone types to one tecplot data loader file.
I work in Fluent 14.0 and tecplot360 2013. So, while exporting quadrilateral or mixed faces zones there were no problem, but on the triangle zone it writes "quadrilateral" but provides only 3 points instead of 4. So, I had to replace "quadrilateral" to "triangle" for zones with triangle faces only. If I replace all the lines in the data file, it can be loaded seccessfully but planar zones contain holes and missing areas.
einandr is offline   Reply With Quote
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 15:35
FLUENT results to ANSYS Jin Yan FLUENT 2 April 28, 2011 11:22
tecplot vs CFD-POST for Fluent post-processing sunflower FLUENT 0 November 10, 2010 01:50
CFX vs. Fluent Results n.sharifi CFX 8 November 3, 2010 16:40
how do I import tecplot file to fluent Kangello FLUENT 0 December 2, 2009 08:28
