fluent problems
Like Tree1Likes
Old   December 24, 2013, 08:47
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
hey,
you don.t need to worry much about that line... it will be disappeared with respect to iterations. I ran many simulations on species transport ( non reacting). At iterations stage below 100, you might find that. But later, it will be calculated and disappeared
Regards,
Sampath Surya
sampathevs is offline   Reply With Quote
Old   December 24, 2013, 08:48
hey,
Regards,
Sampath Surya
Old   December 24, 2013, 08:51
Zaktatir is on a distinguished road
So,
if you are still getting theses messages after long simulation time then you have a problem in your setup. Increasing the value to such a high holdup and still getting these warning this depicts that something is wrong or the turbulence model which you are using is false or you have very big eddy length scales.
Please post your settings setup (turbulence model /turbulence inlet sepcifications, Boundary Conditions, Picture of your problem)
Zaktatir is offline   Reply With Quote
and changing the limits in solutions does not effect your problem. i mean, turbulence viscosity limitation. JUst run more iterations .. you will not see that line anymore.
That appears due to the boundary condition values. I mean, the values and properties you gave might not be that accurate.
Old   December 24, 2013, 12:11
WE have to change the limits if we are simulating a large/full scale geometry!!!
But your are right he has to share with us his model specifications!
Old   February 5, 2014, 01:43
annu is on a distinguished road
The mesh contains high aspect ratio quadrilateral,
hexahedral, or polyhedral cells.
The default algorithm used to compute the wall
distance required by the turbulence models might
produce wrong results in these cells.
Please inspect the wall distance by displaying the
contours of the 'Cell Wall Distance' at the
boundaries. If you observe any irregularities we
recommend the use of an alternative algorithm to
correct the wall distance.
Please select /solve/initialize/repair-wall-distance
using the text user interface to switch to the
alternative algorithm.
annu is offline   Reply With Quote
Old   February 5, 2014, 01:44
how to resolve this issue?
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
problems running fluent through matlab galapago FLUENT 1 October 10, 2013 10:20
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) cici Main CFD Forum 0 September 29, 2011 15:28
Problems with FLUENT MPI on i7 2600K/P8P67 TaurusASV FLUENT 1 May 5, 2011 12:58
Problems with Fluent Jacek Main CFD Forum 2 August 16, 2002 05:14
