Hypermesh To Fluent
Like Tree2Likes
  • 2 Post By hellorishi
Old   November 13, 2008, 05:15
Default Hypermesh To Fluent
Raghu
Hi friends is any body using hypermesh software for meshing and exporting to fluent, because i have some doubts in exporting the file to fluent.Thanks
With regards, raghu
Old   November 13, 2008, 06:12
Default Re: Hypermesh To Fluent
selvag
Hi, in hypermesh you have to export as .nas file and in fluent use import option(file-import-nastran).
Old   November 13, 2008, 17:42
gregorio
You can export a .cas file directly with an additional package in Hypermesh. (you can read or write .cas files and you can also read .msh files)
Old   November 14, 2008, 07:04
Raghu
Hi friends,
Hope u r using hypermesh for ur analysis, can u tell me the how is the mesh produced by hypermesh software for Fluent interface. Is is good or not because its generally used for structural analysis. Can u help me out pls.
With regards, Raghu
Old   November 14, 2008, 12:38
gregorio
Of course you have to mesh using tri/tet elements. I work only doing mesh of surfaces (I use tgrid to do the 3d mesh).
My geometries are complex. When I have problems with mesh, it is because of difficulties of geometry (skewness). It is easy when you need to improve skeness. When you work with elements linked to the geometry, it is very easy to modify the mesh.
I can not compare with other software because it is the only that I know.
Old   November 18, 2008, 03:37
Horner
Hi Geogorio,
What do you just use HyperMesh to produce the mesh of surface? Is the solid elements created by HyperMesh not suitable for Fluent? Thanks.
Old   November 18, 2008, 16:03
gregorio
The solid elements from Hypermesh should be corrects for Fluent. I have tried to work with 3d elements from Hypermesh but at the moment, for me it is longer than doing the 3d elements with Tgrid.
Old   December 2, 2008, 05:24
Horner
Thanks for your reply. Now I'm studying the thermal problem of electronic devices. Due to the complex of geometry, I have to use Hypermesh to produce mesh and import to Fluent. Now I face a problem that I can't import the 2D interface elements between sold and fluid parts into Fluent. Some error messages will happen. If I neglect them, Fluent will produce the interior interface automatically but not complete. Thus I can't assign all coupled wall. Although I can use Gambit to assign these wall but it's too boring. Do yo have any suggestions? Tanks a lot.
Old   December 10, 2008, 03:37
Wifi Lee
Hypermesh is not the most appropriate software for cfd simulation.If you want prcise result,I can gridding for you.
Old   December 29, 2008, 02:43
Milind Khedkar
You can use hypermesh only to generate the surface mesh. Then transfer it to Tgrid and generate volume mesh. then import in fluent.
Hope it will solve your problem. Milind
Old   November 2, 2013, 13:09
Default Import Hypermesh file to fluent
  #11
Farshad Rezaei
Farshad585 is on a distinguished road
I've produced 3d mesh with Hypermesh, but I don't know how to import it to fluent,,My Geometry is too complex and hypermesh is the only choice for me. Fluent 14.1 can import Hypermesh file directly, but it shows an error,could any body help me?
Farshad585 is offline   Reply With Quote
Old   December 11, 2013, 03:35
Rishi .
hellorishi is on a distinguished road
HI Farshad,
Dont know if the issue is still unresolved. Anyways, HyperMesh has a direct export to Fluent. It is possible to generate .cas/.msh files
http://www.altairhyperworks.com/hwhe...for_fluent.htm
http://www.altairhyperworks.com/hwhe...m?cfd_1000.htm
Farshad585 and bloodyzohair like this.
hellorishi is offline   Reply With Quote
Old   December 12, 2013, 01:26
Farshad Rezaei
Thnak u Hellorishi
Hypermesh file to Fluent Logesh FLUENT 1 November 30, 2011 13:46
Exporting mesh from FLUENT to HYPERMESH or LS-DYNA Subramani Sockalingam Main CFD Forum 3 February 19, 2008 07:34
Hypermesh and Fluent carno FLUENT 1 September 8, 2007 23:29
Hypermesh used for Fluent ?? Boris FLUENT 2 January 27, 2003 21:05
Exporting HyperMesh file to fluent 5 Ricardo FLUENT 0 July 6, 2000 04:18
