Porous Media initial temperature calculation and definition |
December 10, 2013, 08:56 |
misterdd
Hi CFD experts,
I want to simulate heat transfer through heated porous zone. While cold air passes through porous media which results in raising temperature of air. initially air is at 300k mass flow is 3kg/sec air temperature after leaving porous zone should be around 500k transient analysis is required to be done for 10 seconds. Now the question is: how to calculate and define initial temperature of porous zone? |
December 11, 2013, 22:09 |
You mean to define an initial teperature only for porous zone?
If this is your problem you can try, after solution initialization, to patch a temperature to the zone you want, with the bondary condition for air at 300 k. |
December 12, 2013, 11:57 |
misterdd
Thanks for your response M123. I will try it for sure.
December 16, 2013, 13:48 |
misterdd
well, patching defines initial temperature to porous zone, raising the air temperature passing through it.
Now i want to study the temperature drop in porous zone as a result of heat transfer from porous zone to air. ANY IDEAS? |
heat transfer, porous zone |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 22:25 |
PHOENICS 3.5 temperature calculation | Jas | Phoenics | 2 | January 15, 2004 07:11 |
initial value file | Olivier | CFX | 2 | September 19, 2002 00:01 |
