Mass flow inlet and pressure outlet issue
Old   July 12, 2011, 13:49
Default Mass flow inlet and pressure outlet issue
Nik
nikhil is on a distinguished road
I am analzying following case in Fluent.
-> 3D
-> Transient
-> Mass flow inlet BC (Transient Mass flow, Always positive)
-> Pressure Outlet BC (Static Pressure = 0 Pa)
With the above setup, when i monitor the static pressure at the inlet, i am getting negative static pressure at inlet.
Thus there is a negative pressure at inlet and 0 Pa at outlet. Technically, there should be a reverse flow, but Fluent shows no reverse flow.
Also, as my inlet mass flow bc always applies postive value for mass flow rate, static pressure at the inlet should always be higher than the outlet pressure, shouldn't it?. But i am getting it completely opposite.
Any comments why this is happening?
nikhil is offline   Reply With Quote
Old   February 17, 2012, 17:16
famerfamer is on a distinguished road
static pressure is not the driven force for the flow but it is the dynamic pressure. If you set outlet pressure as 0, the inlet pressure can be negative because of the pgh, the hydraulic pressure. But it depends on the difference of the hydraulic pressure and the inlet dynamic pressure.
Hopefully it helps.
famerfamer is offline   Reply With Quote
Old   February 18, 2012, 08:51
delaneyluke is on a distinguished road
Hi Nikhil
What is it you are analyzing?
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   March 16, 2012, 00:17
banty
banty is on a distinguished road
Mass flow rate allow the total pressure to vary in response to the interior solution. on the other hand the pressure inlet BC, total pressure is fixed and the mass flux varies. A mass flow inlet is used when it is more important to match a prescribed mass flow rate than to match the total pressure of the inflow stream. so, if u are more interested with pressure then using pressure inlet BC may be good idea.
-> 3D
-> Transient
banty is offline   Reply With Quote
Old   December 11, 2013, 12:16
Default Total Pressure
MDB
Manuel Díaz Brito
MDB is on a distinguished road
Hi all,
I know I am joining quite late, but think that I can still contribute a bit.
You should check the total pressure (static + dynamic), and recall that the dynamic pressure is \frac{1}{2}\,\rho\,\cdot\,{u_{\infty}}^2, hence whenever the mean velocity is high, the dynamic pressure is so.
With mass-flow-inlet and pressure outlet, Fluent will work out the pressure at the inlet for your flow to be possible. Verify that the mass-flow out matches the flow rate you are imposing, and should the computed pressure at the inlet not match your known pressure at the inlet, update the imposed pressure at the outlet (static and gauge) and keep your simulation running.
Hope it helps,
MDB
MDB is offline   Reply With Quote
Old   December 11, 2013, 12:30
Zaktatir is on a distinguished road
Manuel has said already what i usually suggest to my folks:
-Check the total pressure / Mass flow
-Check Convergence
-Check your reference pressure (mean for incomp/ zero or mean for compr)
Zaktatir is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
