Iso-surface plot
Old   December 25, 2013, 07:43
Default Iso-surface plot
le hoang anh
lehoanganh07 is on a distinguished road
Dear Fluent User,
I am modeling cavitation in 3-D Nozzle. I try to plot cavity as in the picture below ( the cavity appare in the Nozzle hole). I tried to use Iso-surface but it not work as I expect.
Could some one help me how to do that?
Thank you very much!
(Sorry I dont know hoe to add image in the forum)
This is the image of my model
http://img577.imageshack.us/img577/2517/3p2f.jpg
And this is the example cavity plot which I want to do
http://img29.imageshack.us/img29/1276/xmi6.jpg
lehoanganh07 is offline   Reply With Quote
Old   December 25, 2013, 11:33
Zaktatir is on a distinguished road
I don't understand: are you asking by which variable you want to the create the iso-plot?
You may create the isoplot by means of the void fraction and then using another variable for post-processing on the created surface
Zaktatir is offline   Reply With Quote
Old   December 25, 2013, 20:16
le hoang anh
Thank you,
I mean do you know how to use Iso-surface or onothe option in Fluent to plot the cavity structure as in picture I posted above?
I used contour plot but it just show the position of cavity and we could not see the cavity struture(3D), also I tried to use Iso-surface as advice from anothe topic in Forum or in Fluent guid, but it still not work
Old   December 26, 2013, 05:15
by which variable is the cavity specified? VOF or anything else?
Old   December 26, 2013, 09:12
le hoang anh
Yes, the VOF
Old   December 27, 2013, 07:58
then follow my first reply and then we will see
Old   December 27, 2013, 08:20
le hoang anh
Thank Zaktatir,
But could you tell me detail how to do that? I dont clearly understand you reply
Old   December 27, 2013, 10:34
-1/Create a Surface by Iso-Value (Iso-Surface)
2/ Choose VOF as the variable of interest and give a reference Value
3/Then you have now a new surface which may be used for further post-processing
By the why how high is the void fraction for your cavity (0,5?)?
Old   December 27, 2013, 22:12
le hoang anh
I dont kown what value should use, because the VOF value from 0.1 to 0.9
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 01:44
STL units and Surface elevation plot MAB FLOW-3D 11 May 9, 2010 15:55
Is it possible to plot streamline on a user surface fkzstar CFX 2 April 8, 2009 05:30
Can I plot a surface integral as function of time? Cagdas FLUENT 0 October 24, 2007 17:04
