determine surface height without input (open channel ; free surface and bottom) given |
December 30, 2013, 03:09 |
stefanus tobing
Rep Power: 12 |
hi all, happy welcome the new year,
I really need your help, i hve tried this with open channel, i think it's not proper way, because i set the height of the surface, but in my case, i should make the water can adapt surface height by gravity work on it without input given (without entering data in open channel ; free surface and bottom), then the water free out like a waterfall into the tank. please, help me. thank you so much surface vortex3.jpg Stefanus Tobing |
December 30, 2013, 03:17 |
stefanus tobing
Rep Power: 12 |
sorry my question is, what parameter and boundary should i use? thx
December 30, 2013, 04:05 |
Then normal BC's like velocity inlet and pressure outlet. For postprocessing the height of your surface will be given with the product of the volume fractions
December 30, 2013, 05:18 |
stefanus tobing
Rep Power: 12 |
thx but do i still use VOF - "open channel" in model and without click open channel in multphase tab on BC
or only VOF ? |
December 30, 2013, 06:04 |
Only VOF with open channel flow at first stage
December 30, 2013, 07:48 |
stefanus tobing
Rep Power: 12 |
what first stage is mean? sorry, i can't understand. please, explain to me. i'm new inthis field
it's my work, but still divergence, after set the BC as your suggest. Transient with VOF + open channel, BC, Volocity inlet : 1,4 m/s and Pressure outlet (default), then compute from velocity inlet, then calculate with 200 iteration. mesh.jpg |
December 30, 2013, 09:20 |
I only suggested to USE VOF since you said that open channel flow is not quite giving the right results. You have to check the whole setup and five us more details. By the way why did you start with the open channel hydraulics? Do you have experimental values for the heights of waves at inlet and outlet?. Your Geometry looks like a cyclone. And the mesh is very coarse.
I suggest to start with tutorial or simple duct and carry on a VOF simulation of free surface flow. |
December 30, 2013, 10:37 |
stefanus tobing
Rep Power: 12 |
with pleasure, i will give the the detail,
open channel hydraualics? sorry..i don't know where it start, and i don't have any experimental values of the wave height for both inlet and outlet, actually, this is simplification case of my work, because i'm new. i simplify the case as water free out to the tank. yes, you correct it is a cyclone, i want make water vortex flow, with hole outlet in bottom of tank, but it is still so far for me to understand to make this simulation.. |
December 30, 2013, 10:51 |
stefanus tobing
Rep Power: 12 |
i'm sorry about the mesh, i thought because it's just example, it's okay if i use coarse mesh to speed the iteration, i will correct it
thx |
December 31, 2013, 07:33 |
stefanus tobing
Rep Power: 12 |
hi hi,, sorry to make you wait long Zaktatir, i hve worked quite much in this day,,
here is the details, please 1.A dimensi.jpg 1.B mesh.jpg 1.C GENERAL.jpg 1.D MODEL.jpg 1.E MATERIAL.jpg i feel, i'm wrong in solution control and solution initialization, and other such, BC and CellZoneCondition bacause i put default btw the mesh quality is not good enough, is it? |
December 31, 2013, 07:35 |
#11 |
stefanus tobing
Rep Power: 12 |
1.G CELL ZONE CONDITION.jpg 1.HBOUNDARY CONDITION.jpg 1.I SOLUTION METHOD.jpg 1.J SOLUTION CONTROL.jpg |
December 31, 2013, 07:38 |
#12 |
stefanus tobing
Rep Power: 12 |
1.L SOLUTION INITIALZATION.jpg 1.M CALCULATION ACTIVITIES.jpg 1.N RUN CALCULATION.jpg |
December 31, 2013, 18:52 |
#13 |
stefanus tobing
Rep Power: 12 |
hi, Zaktatir
i did as ur suggest to start it with simple duct, i hve made a tub with a duct on it in 2D, and it work but i got problem, the case, I want to fill the tub until it is full with water in 2D. I use time step size low = 0,1; number of time step = 100; auto save every(time step) = 10 i need time until 60 s, until the tub is full but in interation (before the tub is full) i got error message in 2 s, . the tub is not full yet what things should i change? ps: error "Global courant number is greater than 250.00 The velocity field is probably diverging. Please check the solution and reduce the time-step if necessary." thanks alot, if you can help me, this now. happy new year Attachment 27667 |
January 2, 2014, 13:38 |
#14 |
stefanus tobing
Rep Power: 12 |
thx Zaktatir, i've solved the problem now,
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 16:26 |
UDF for inlet BC, Free Surface Open Channel Flow VOF | arshiya4 | Fluent UDF and Scheme Programming | 3 | March 6, 2012 18:13 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 14, 2010 23:54 |
open channel problem (free surface) | Andy Chen | FLUENT | 4 | July 10, 2009 01:20 |
Open Channel Boundary Conditions via journal | Matteo | FLUENT | 0 | January 21, 2008 11:05 |
