January 6, 2014, 16:18 |
Nozzle of turbojet engine
KK
Rep Power: 12 |
I want to count the heat exchange in the nozzle of turbojet engine. I've created a model of this engine and I used following settings: http://wrzucaj.net/tHj This is only 1/4 of model. Solver: density-based Energy: ON Viscous: standard k-E Air: Ideal-gas Boundary conditions: - pressure inlet: gauge pressure=203990.4 Pa and Temp=1000 K, operating conditions -> pressure=0 Pa - pressure outlet: gauge pressure=472655.75 Pa and temp=890 K - symmetry for every wall 'inside' - wall for outer surface: convection with heat transfer coefficient 58 w/m2-k , free stream temperature=220 K and wall thickness=1 mm Reference values: compute from: pressure inlet Flux type: AUSM Solution Initialization: compute from: pressure inlet What do you think about that? I've had some troubles and errors like 'backflow' , "time step reduced...' , divergence... |
January 7, 2014, 03:35 |
duri
Rep Power: 16 |
January 7, 2014, 14:44 |
KK
Rep Power: 12 |
Because it is a convergent nozzle. I have written about exhaust nozzle.
January 11, 2014, 15:11 |
KK
Rep Power: 12 |
Could anyone help? How to model this kind of flow?
January 19, 2014, 18:14 |
Shawn Fotovati
Rep Power: 16 |
You could also try pressure based solver. Also try k-w or sst models for turbulence. k-e is more suitable for external flows. double check your mesh and make sure there is no problem with the mesh. Use SIMPLEC.
good luck |
January 20, 2014, 08:19 |
#6 | |
ugurcan gördük
Rep Power: 13 |
I didnt understend conditions at outlet. dont u talk about nozzle to air outlet? if it's like that condition should be like; presure 0 pa and temp 280-290 K. |
Convergent-Divergent Nozzle with MATLAB | Obad | Main CFD Forum | 8 | June 2, 2020 14:10 |
Boundary Conditions for Podded Engine | ferocity | CFX | 2 | October 28, 2013 16:43 |
Jet Engine Nozzle Test Case | paduchev | FLUENT | 0 | November 18, 2012 23:42 |
Help me design a conv-div nozzle for race engine! | MaxCFM | Main CFD Forum | 29 | May 30, 2009 18:11 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
