Supersonic Flow Error
Old   January 20, 2014, 12:53
Default Supersonic Flow Error
osuguy is on a distinguished road
Hey all,
I'm trying to model a Mach 2 flow over a missile. However I keep getting errors in the middle of my simulation saying "time step reduced in 3 cells due to excessive temperature change". I get a similar error for pressure as well. I attached a pic of my mesh and the error (along with residuals) for reference.
I feel this problem is due to wrong boundary conditions and I'm new to supersonic flows in Fluent. Here are my settings:
Density solver
Transient
Inviscid with energy equation on
Density as ideal gas
Constant specific heat
Boundary condition: -On the far boundaries (inlet and far from the missile) chose a pressure farfield setting with Gauge=101325Pa, Mach 2, 300K and the flow direction
-On the outlet chose pressure outlet with Gauge=0Pa normal to boundary
-Operating pressure=0Pa
Solution initialization: compute from inlet
Solution Methods: Implicit, AUSM flux, Gradient=Green Gauss Cell Based, Flow=3rd order MUSCL
CFL=2
Residuals at 1e-4
Time step=.1
Max Iterations/step=20
Let me know what you think. Thanks.
osuguy is offline   Reply With Quote
Old   January 20, 2014, 13:11
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Compressible supersonic flows are not my strong point, but are you sure it is a good idea to set both the gauge pressure and the operating pressure to zero?
The time step size seems may be way to high and I would not start the first simulation with a third order scheme.
It might aswell have to do with bad mesh quality, but unfortunately there is nothing to see in the picture you posted.
Does the simulation really have to be transient?
flotus1 is offline   Reply With Quote
Old   January 20, 2014, 13:25
I read somewhere on these forums that supersonic flows needed 0Pa for the operating pressure. As far as the gauge pressure it's only 0 on the outlet, but 101325Pa in the farfield and inlet, but thinking about that twice I feel that they should be consistent (maybe I'll try both at 101325Pa).
I don't believe is is the mesh quality, at it has roughly 8.5 million cells (although I'm not sure about the orthogonality of the mesh). The mesh radius is roughly 20 diameters away.
I chose transient due to that it is slightly easier for Fluent to solve (as opposed to steady where some damping of the solution occurs). I was going to run transient until a steady state is approached. I don't really have a reasoning for the time step size though, I'll try some lower.
Old   January 20, 2014, 13:32
I should also add that I get this same "time step in 3 cells changes due to excessive temperature change, reducing the CFL to something lower" regardless if I use a steady OR transient solver.
Old   January 20, 2014, 13:41
flotus1's Avatar
Alex
Mesh quality and cell count are not related.
Check the mesh quality explicitly.
Operating and gauge pressure set to zero result in an absolute pressure of zero (as far as I know) which could explain one of the error messages you get.
Old   September 14, 2019, 07:52
yemai is on a distinguished road
Hello, I recently met this problem, very like your first picture, and I also make a model about a Mach 2 flow in the combustion chamber. So, could you please give my some advises?
yemai is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
