Fluid Structure interface - Negative Volume
Old   January 18, 2014, 09:19
Default Fluid Structure interface - Negative Volume
Mohammad Cheikh
mohammad.cheikh is on a distinguished road
Hi I am doing a fluid structure interface simulation on ansys. I have a simple problem where I apply a sinusoidal pressure P=Pmax*sin(2*pi*fr*t) on a solid membrane and in turn the solid membrane will compress the fluid and the fluid pressure will increase. The time step I use is always = 1/20 of the period or 1/f.
I done this simulation with time step ranging from 0.1 to 0.005 and no problem occured, however when I apply smaller time steps the simulation would give me negative volume on the 3rd iteration.
Can someone please explain why does the time step affect the defomration??
Thanks
mohammad.cheikh is offline   Reply With Quote
Old   January 23, 2014, 12:35
Carl Schultz
pvtschultz is on a distinguished road
I am working with a sort of similar situation. This is a tip that I received from Ansys.
There is an rpvar in Fluent which you can use to slow down Fluent convergence- which will also damp out the pressure oscillations. This is:
(rpsetvar 'dynamesh/sc-bc-compressibility-type 1)
(rpsetvar 'dynamesh/sc-bc-compressibility 0.1)
See solution #2022119 for more explanation on usage. Second parameter needs to be decided based on trial and error.
The video in solution 2022119 goes through how to sort it out. Though, I haven't fixed my problem yet...
pvtschultz is offline   Reply With Quote
Old   January 23, 2014, 14:49
Thumbs up Thanks for the reply
Mohammad Cheikh
Thanks alot for your reply I applied what you told me and it worked.
Courant number blowing up, non-orthogonal mesh? odellar OpenFOAM Running, Solving & CFD 5 October 22, 2013 19:50
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
negative element volume (CFX-10.0) CFDworker CFX 8 September 27, 2011 18:16
blockMesh error ... balkrishna OpenFOAM Pre-Processing 0 August 17, 2010 02:39
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
