Lift Coefficient vs Angle of Attach for Pitching Airfoil |
January 29, 2014, 04:16 |
Musa
Hi Everyone,
I am performing airfoil Pitching in fluent using UDF. I am using this equation alpha = alpha(o)+alpha(a)*sin(Wt) alpha(o) = mean angle of attack (10) alpha(a) = pitching amplitude (15) My problem however is how to plot the lift coefficient vs AOA as shown in the picture below. Normally in the static case, you specify the angle of attack for x and y in fluent and report the forces after simulation for each angle of attack. Which means you have to run a lot of cases if your aoa is between (-5 to 25). However looking at the pitching case and the picture I do not know to plot it. Please any help will be appreciated. Regards Franklyn |
July 9, 2014, 05:26 |
Pras
Rep Power: 11 |
Could you help me with the solution to the problem you mentioned. How to determine the Cl vs AOA for pitching airfoil? |
July 9, 2014, 12:00 |
#3 | |
Syavash Asgari
Writing a UDF is one tool which can help you plot Cl vs. AOA. But have in mind that solution of a dynamic pitching airfoil is different from the static airfoil. Goodluck |
July 16, 2014, 08:35 |
Pras
Rep Power: 11 |
Does anybody have any example of an airfoil pitching UDF with the AOA part on it, which will give me the AOA at every time step? Regards, Pras |
airfoil lift and drag coefficient | amir_14 | FLUENT | 5 | January 1, 2013 09:30 |
Determining Stall Angle of 2D Airfoil | Active.Aero.Fiero | FLUENT | 3 | October 27, 2010 10:07 |
Lift Coefficient of an Airfoil. | pandelis chatzis | Siemens | 2 | September 5, 2002 04:00 |
Lift Coefficient Vs. Angle of Attack | cfd_pro | Main CFD Forum | 1 | August 23, 2002 18:21 |
Highest lift coefficient | Mark Render | Main CFD Forum | 5 | March 2, 2000 09:30 |
