Iso-surface? Iso-clip?
Like Tree5Likes
  • 3 Post By ghost82
  • 2 Post By Kokemoor
Old   September 25, 2014, 22:31
Default Iso-surface? Iso-clip?
Michael
mjkey is on a distinguished road
Hey guys,
I'm modelling the interior cabin of a vehicle and one of the main values I wana know about is the mass-flow rate around the driver head. Please note that I do not have the manikin model in the car, but I have the seats and steering column. The driver head is going to be approximately just in front of the seat, and I wanted to evaluate the mass-flow around that area, to get an idea of how much air is reaching the face of the driver.
I've tried using the surface-plane but this just gives a whole cross-section of the car cabin. I've heard some things about using iso-surface/iso-clip but I have no idea how to do it. I just want like a small rectangular (or whatever) surface near that driver face region(which means its just sitting there in the middle of the flow field). Is this possible to be done via iso-surface/iso-clip?
Cheers!
mjkey is offline   Reply With Quote
Old   September 26, 2014, 05:37
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I know for sure you can do it in cfd-post by using iso-clip.
Supposing the air flow is mainly perpendicular to an yz plane.
In cfd-post create the yz plane, you know where the passanger's head is, so you can set the x coordinate.
Then create the iso-clip on this plane to cut it by setting z<=..., z>=..., y<=... and y>=...
Maybe this is possible also in fluent, never used it.
Daniele
fruitkiwi, Ankit.Dave and Zalan like this.
ghost82 is offline   Reply With Quote
Old   September 26, 2014, 10:28
Andrew Kokemoor
Kokemoor is on a distinguished road
Yep, the process is the same in Fluent. You can make a plane with Surface->Plane and then a subset of that surface with Surface->Iso-Clip using the variables Mesh...Y-Coordinate and Mesh...Z-Coordinate.
ghost82 and Zalan like this.
Kokemoor is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
Vorticity iso surface around propeller in CCM+ Dan Siemens 2 January 23, 2007 14:17
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
