Non-zero dynamic pressure on the wall in Fluent |
February 20, 2014, 10:29 |
I have an ambiguity in Fluent results of dynamic pressure on the wall. Shouldn't it be zero. If I assume that it takes cell centre values, the velocity in the first cell should still be near to zero (very very small) but the value of dyn press. is very high that is around 90,000 that gives velocity of 382 m/s with air as medium. Please give me some suggestion on that. The flow is modelled laminar by the way.
August 3, 2018, 03:25 |
Rep Power: 13 |
i have the exact same problem in understanding what Fluent does when it calculates the dynamic pressure on walls. On the wall velcity = 0 in all directions. Where does the velocity on the wall comes from, so that Fluent calculates a non-zero dynamic pressure, which i assume is a Force/per are acting on the wall. Can i use the dynamic pressure profile on a wall from Fluent to calculate mechanical load on an area? |
August 3, 2018, 09:57 |
Lucky
Rep Power: 65 |
When you select a wall on a variable that exists only in the interior (i.e. temperature), Fluent takes the value of the cell adjacent to the wall. Maybe that is what is happening here.
August 3, 2018, 12:44 |
#4 | |
August 6, 2018, 04:20 |
#5 | |
Rep Power: 13 |
From my limited understanding of the matter i would think that the correct pressure to use for Force Calculation would be the static pressure, since total pressure would be equal to the static pressure at the stagnation point (= wall, where velocity is zero). I have to check how fluent calculates the Forces. It only says "Pressure Force" in the manual, but i suspect it's actually the static pressure on a wall... Last edited by BlnPhoenix; August 6, 2018 at 05:41. |
April 18, 2023, 03:44 |
Ali Burhan
Rep Power: 9 |
Hi all,
I have exactly same two questions: 1. Dynamic pressure is ρV2/2. We may expect that to be zero at wall. But appearently it is not. I assume it takes the first cell center velocity value, thats why dynamic pressure at wall is non-zero. Am i correct? 2. What should we take for mechanical load? Static pressure is due to the perpendicular force. I guess dynamic pressure is related to the viscous force parallel to the surface. Static pressure sould be included to the mechanical load in any case. But dynamic pressure should be included if only it affects our moments in mechanical case, but not as pressure values as Viscous Force value with directions. Am i correct? What is your opinion? Thank you |
April 19, 2023, 13:46 |
#7 | |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
