Temperature Miscount
hello!!
i am working a simulation on radial gas turbine. i am using energy and k-epsilon model. setting boundary on inlet as mass-inlet and outlet as press-outlet. after running the simulation, i find that the temperature outlet is just the same with inlet. is there any suggestion? |
Suggestion 1: your simulation correctly described what is happening, and the temperature at the outlet really is the same as in the inlet.
Suggestion 2: you did not calculate the energy equation. Check at 'Models' if the energy equation is really on, and check at 'Solution controls'->'equations' if it is also calculated. Is the temperature everywhere in the domain the same, or only at inlet and outlet? |
