How to show vector of Axial velocity in 2D plane? |
March 11, 2014, 10:04 |
Rep Power: 12 |
Dear all
I simulate 3D stirred tank. The height of tank is in z-direction. I have some problem about how to show vector of axial velocity in a desired plane (xz plane). P.S. Thank in advance Regards Eakarach |
March 12, 2014, 06:30 |
Rick
Rep Power: 26 |
create a plane, then show vectors in that plane; in vector options select "in plane". Daniele |
March 12, 2014, 08:10 |
Rep Power: 12 |
Thank you. Yes, I do as your comments. But, i want to show only axial velocity vector not velocity vector.
Regards Eakarach |
March 12, 2014, 09:51 |
Rick
Rep Power: 26 |
Ok, I understand.
I think it's not possible in fluent, but you can do it in cfd-post if you have it. Simply create the plane, then create vectors on that plane and choose Projection "Coord frame" and choose as direction X or Y or Z. Daniele |
March 13, 2014, 06:21 |
#5 | |
Rep Power: 12 |
I want to show vector like the attached figures. Please tell me the way to show these figures. Thank in advance Eakarach Last edited by Eakarach; March 13, 2014 at 07:23. |
March 14, 2014, 04:37 |
Rick
Rep Power: 26 |
I was able to do it in tecplot.
Put a tick (select) on Slices on the left. Create the slice (plane) you want to show vectors: click on the button with "..." next to "slices"; go to vector tab and select "show vectors" (a window pops up, select U as x velocity, V as y-velocity and W as z-velocity) and "tangent vectors"; click on line color and select "multi 1"; close the slice tab. Go to Contour tab and deselect "show contours". Click on the button with "..." next to "contour", on the left; select from the top x-velocity (or y velocity, or z velocity); change the levels if you need; Daniele EDIT: just to point out that what you requested is not vectors of axial velocity, but vectors of in plane velocity coloured by axial velocity. Last edited by ghost82; March 14, 2014 at 09:25. |
March 14, 2014, 16:47 |
Rep Power: 12 |
Thank you for you help very much
Display Modes | |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
How to get cut plane of velocity from axisymmetric run | aerospain | OpenFOAM Post-Processing | 0 | November 20, 2012 07:02 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 22:34 |
how to plot out circumferentially mass averaged axial velocity in a rotor? | wildli | FLUENT | 0 | July 17, 2010 15:54 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
