Transient Conjugate Heat Transfer
Old   March 11, 2014, 11:01
Default Transient Conjugate Heat Transfer
anonymous
aditya92in is on a distinguished road
hello, i have a small doubt..i am simulating conjugate heat transfer, in this a fluid flows through a pipe and the pipe is attached to a plate, i want to just see how the temperature of the plate varies with time, how and where do i set the initial temperature of the plate, the fluid inlet temperature is 1000 K, in my solution, it is taking the initial temperature of the solid at t=0, not as 298 K , but at 1000K itself, please could you help me
aditya92in is offline   Reply With Quote
Old   March 11, 2014, 11:32
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hello adytia,
I suggest setting Flow temperature as boundary condition, then set 298 K in the Solution Initialization Menu - Initial Values (Patch Submenu also could be useful in your case) for the plate
Regards
Bionico
Bionico is offline   Reply With Quote
Old   March 11, 2014, 11:45
anonymous
ok...ill do that and get back to you..thank you
Old   March 11, 2014, 19:39
anonymous
I tried it , but it does not take it, when i put 298 K as initial condition, it takes the entire solid at 298 K ,and never changes at all, for the rest of the simulation, even i apply convective boundary condition on the other boundary, i hav attached images for your reference, pls have a look
Old   March 11, 2014, 19:40
anonymous
this mite be because, i did not create named selections for the solid domain..ill do that and tell you
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? rogbrito Main CFD Forum 1 February 19, 2019 02:11
conjugate heat transfer in a rotary condition rasekh64 FLUENT 4 June 19, 2013 03:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
