ill posed problems: inverse heat transfer
Old   August 1, 2001, 08:34
Default ill posed problems: inverse heat transfer
rajeev
Hi everybody !
Can Fluent solve ill posed problems. I mean inverse heat transfer problem. i.e if I know what is the temperature of certain locations inside my domain (not on the surface) by inserting thermocouple and monitoring temperature with time. Can I use this data and calculate the heat transfer coefficient at the boundarys.
Hope I have made myself clear. If anyone has used fluent to do this please let me know how.
Thanks in advance
Rajeev
Old   August 1, 2001, 11:24
Default Re: ill posed problems: inverse heat transfer
AJ
It could be possible if Fluent allows BC on nodes using UDFs. Read manual whether Temperature can be applied as BC on nodes!
Old   August 2, 2001, 05:11
Alain
Unfortunatly you can't do that with fluent.
This problem is an inverse problem and can only be handle by an inverse code. As far as I know inverse methods in cfd are still under development due to the strong non linearity of the NS equation.
I think that this problem have allready be debated in cfd online and that you will find more information by searching the database.
Old   February 19, 2019, 02:00
Default inverse heat transfer
alireza javadpour
alireza7246 is on a distinguished road
hi all, i have a square with heat generation rate inside that, i have three boundary conditions with constant temperature, but i dont have heat flux from one of walls, i want to simulate this problem in Fluent, could you please any one explain me??
alireza7246 is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
heat transfer in two-phase flow Leonid Fromzel CFX 0 April 8, 2008 05:57
error estimates in heat transfer problems srikanth FLUENT 0 August 10, 2007 12:58
