Lift and Drag calculation if wing is porous in nature
Like Tree4Likes
  • 1 Post By mooby
  • 1 Post By mooby
  • 1 Post By mooby
  • 1 Post By Kokemoor
Old   March 14, 2014, 08:22
Default Lift and Drag calculation if wing is porous in nature
Mubashir Ali
mooby is on a distinguished road
Send a message via Skype™ to mooby
Hi PPL,
I want to calculate lift and drag coefficients of wing whose leading edge has a cut so that air can actually go inside the wing and wing is made of porous material . for example nylon.
I use porous jump to simulate nylon. But drag and lift forces can only be calculated on walls , so in my case how should i do it ??
any suggestions would be appreciated
chocolater likes this.
mooby is offline   Reply With Quote
Old   May 8, 2014, 14:05
i man
chocolater is on a distinguished road
Originally Posted by mooby View Post
Hi PPL,
I have same problem with porous jump. how can calculate drag of it in fluent?
mooby how u solve the problem?
chocolater is offline   Reply With Quote
Old   May 9, 2014, 02:53
Mubashir Ali
Hi chocolater,
Unfortunately, I am still stuck with the problem. I see no solutions at the moment. If in case you get hold of something let me know
Cheers
Mooby
Old   May 9, 2014, 10:49
Andrew Kokemoor
Kokemoor is on a distinguished road
Theoretically, you could measure the difference in momentum flux at your inlet and outlet to get the total force, then subtract off all of your measurable forces from walls. I've never actually tried this, so I can't guarantee its accuracy, but it seems sound. You could try it on a plain wing without the porous jump first to see if it matches the direct force reading.
Kokemoor is offline   Reply With Quote
Old   May 11, 2014, 02:23
Mubashir Ali
Hi Andrew,
It might be an approximate solution .... i doubt in this process viscous forces would be accounted but only pressure forces and in Aerodynamics... viscous forces play a major role
Old   May 12, 2014, 09:50
Andrew Kokemoor
External forces in a momentum balance don't differentiate between pressure and viscous forces, they're treated the same.
cfd seeker likes this.
Lift and drag calculation Franny CFX 16 November 27, 2019 13:47
drag and lift calculation of a cylinder in wind tunnel fewgoodmen Main CFD Forum 4 February 24, 2014 15:05
Lift and drag coefficients of a flapping wing aircraft Julian121 FLUENT 36 August 24, 2012 19:37
Calculation of lift and drag coefficients Prachi CFX 3 August 14, 2007 14:05
Lift and Drag on airplane wing Arj CFX 4 October 6, 2006 04:05
