How to play animation without fluent? With VLC for example? |
March 18, 2014, 04:51 |
Rep Power: 12 |
I have created an animation of an airflow by Fluent. And I can read this animation by the software Fluent but now I wish to play it without using Fluent. So is it possible? For example, I would like to play it with VLC for example so that I can show the video during a presentation for my studies. Any suggestion would be great ! |
March 19, 2014, 07:36 |
anbu
Rep Power: 12 |
results-graphics and animations-solution animation playback- select the sequence file and write/record format change to mpeg and click write. then you can wait for the file to get outputted
March 19, 2014, 07:52 |
Rep Power: 12 |
Thank you for you answer.
But they are just pictures no? I would like a video. |
March 19, 2014, 08:59 |
#4 | |
Rick
Rep Power: 26 |
change to mpeg and click write mpeg is a video format. Anyway, if you have the image sequence you can use quicktime (for example) to play the animation and save to the format you want (mov, mpeg, avi, etc.). You can use also virtualdub to make the video from images; just search in google for "virtualdub creating an AVI from a series of images". |
March 19, 2014, 09:38 |
Rep Power: 12 |
Ok. Thank you very much. That's great !
March 20, 2014, 14:34 |
Rep Power: 12 |
An other opinion to create a videofile is using a programm named: "CFD-Post".
To do so, you must let Fluent write the data in the correct format: Fluent -> Calculation Activities -> Automatic Export -> Create -> File Type: CFD-Post Compatible In CFD Post its possible to render videos via keyframing with lots of animation effects and stuff like Streamlines, Volume Rendering and so on... |
March 21, 2014, 03:13 |
Rep Power: 12 |
Ok, I will test. Thanks !
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
Fluent Animation | FV | FLUENT | 0 | September 6, 2004 09:18 |
fluent animation techniques | khalil | FLUENT | 3 | March 22, 2002 15:15 |
Fluent animation commands | Khalil Bostan | Main CFD Forum | 2 | March 22, 2002 07:36 |
Fluent Animation | FP Mie | FLUENT | 1 | August 3, 2001 21:31 |
