Slow Transient Solution
3 Attachment(s)
I am doing a 2D transient simulation of an aerofoil passing a cylinder to simulate a wind turbine blade passing a tower using a sliding mesh. At the moment my solution is taking quite a while (over 24 hours). A problem I am finding is that I have set the maximum iterations per time-step to be 800 and it seems to use up all 800 for nearly every time-step. I was under the impression that after the solution settles down it should only take ~50 iterations. I have set the time step to be the time taken for the mesh to slide the length of the smallest element. For example I am plotting Cl vs time throughout the solution and I understand that the solution needs to settle (possibly due to limiting it to 800 iterations/time step) but I would assume that after a while. Any help or advice would be appreciated, I have attached some images of the mesh if that helps. |
Hello scoobysimon,
I'm not expert in airfoil (I've never simulated one), but I'd say that usually in transient simulation the number-it/time-step is less important than the time-step value: I never used such a large number of it/time-step (max 20-30). I suggest trying 20 it/time-step and reducing the time-step checking your time-discretization. Regards |
