What model will be adequate?
Old   March 26, 2014, 07:44
Default What model will be adequate?
Tom
blowback is on a distinguished road
I have a question to you. In your opinion which model of flow will be adequate to use in performing simulation described below?
Flow of water through channel that contains dozens of heated rods - heat flux as a boundary condition on rods surfaces.
Velocity inlet: 0.8m/s - mean value of fully developed velocity profile
Pressure outlet
http://s16.postimg.org/bibaa85tv/geometry1.jpg
On the inlet, there are some baffles.
I consider the use of k-omega SST model with Low-Re corrections and curvature correction or k-epsilon standard with enhanched wall treatment.
What do you think about them?
There is boundary layer which consists of 6 inflation layers. Cutcell method was used to create mesh - so boundary layer is the same on all faces beyond inlet and outlet. Whole domain contains ~12 milions of cells.
Thanks in advance for your comments.
blowback is offline   Reply With Quote
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 10:23
eddy dissipation model: combustion doesn't occur roukaia FLUENT 0 December 24, 2011 09:10
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
