pressure drop calcs 0MPa outlet vs 250kPa
Old   March 26, 2014, 17:08
Default pressure drop calcs 0MPa outlet vs 250kPa
Steffen595 is on a distinguished road
Hi all,
I calculated 3 versions of a reducing elbow for pressure drops. First I set the outlet for avg pressure 0, inlet for velocity. Then, because the application is for 250kPa, I set outlet for 250kPa. Now the trouble is, I got 300/900/900 Pa pressure drop at 0Pa outlet, but 3100/2900/2900 at 250kPa, so all off sudden the best elbow becomes the worst. The avg velocity difference is 14.7/14.2/14.2 m/s.
Is the 0Pa result more plausible or the 250kPa?
Thanks,
Steffen
Steffen595 is offline   Reply With Quote
pressure outlet condition setup halfblood@SYSU Main CFD Forum 0 March 15, 2013 23:35
Pressure outlet BC help! eishinsnsayshin FLUENT 7 December 4, 2012 00:36
Pressure drop trend phyiscal not correct in t pipe Vinod FLUENT 0 August 4, 2008 03:43
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Pressure drop calcs Hanan Main CFD Forum 2 February 16, 2000 11:36
