fluent text command doesnt show all options!
Like Tree2Likes
  • 2 Post By Amir
Old   August 30, 2011, 03:41
Question fluent text command doesnt show all options!
Mohammad
m2montazari is on a distinguished road
hi all,
I wanted to write a journal file for fluent to do some changes in case and run them. so I write text-user interface commands in a text file and read it as a journal. but now I want to change some turbulence parameters like the wall treatment options in k-e and RSM; but I cant find how can I set these parameters in text UI? in fluent help it is mentioned that there are many options in /define/models/viscous but when I check in fluent window, it doesn't show all options and I can just choose model of turbulence with no other options!
there may be a command to activate all options in text mode, but I wasn't able to find it.
I use fluent 6.3.26x64 in Linux and the case is a 2ddp case.
thank you in advance,
mohammad
m2montazari is offline   Reply With Quote
Old   August 30, 2011, 04:37
Amir's Avatar
Amir
Amir is on a distinguished road
Hi mohamad,
in /define/models/viscous, first enable the turbulence model then for both ke and RSM the near wall treatment is available in /define/models/viscous; I checked that for a 3ddp case; otherwise, you can also use other journal file preparation method; you can use file->write->start journal, then do what ever you want in GUI and at last in file->write->stop journal, terminate that.
Bests,
sina_mech and akaobi like this.
Amir
Amir is offline   Reply With Quote
Old   August 30, 2011, 05:38
Mohammad
oh you're right Amir!! it was a foolish mistake and also bad user-interface of FLUENT!!
thanks
Old   March 12, 2017, 23:56
Default Initiating PBM
Obed
akaobi is on a distinguished road
Originally Posted by Amir View Post
Hi mohamad,
Bests,
Amir be blessed !
You really saved my day with this.
Initiating the PBM was giiving me a bloody nose
akaobi is offline   Reply With Quote
text user interface, turbulence
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
[ICEM] How to Define a Line separating two Meshes/Regions to not show up as "wall" in Fluent enigma ANSYS Meshing & Geometry 7 April 6, 2009 12:20
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 14:22
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 12:49
