why the cavitation incepts in the area of high pressure ? |
April 23, 2014, 10:11 |
cuocuozhuo
Rep Power: 12 |
I use the software FLUENT 14.5 to simulate this case.
I use liquid-vapor two phases method:I choose the k-e model, two phases mixture model and s-e-a model. Boundary conditions are as followsressure inlet,total pressure is 101325 Pa; volume fraction of vapor is 0 at the inlet.; Pressure outlet, 0 Pa. The result shows that the pressure in upstream area is higher than 8.8e +04. I think there shouldn't be cavitation. But the result shows that the vapor volume fraction is higher than 6.5e-03. I don't think it is reasonable. I tried other models like schnerr-sauer model and zwart-gerber-belamri model.The results are same as this. I think maybe you can help me. Thank you. |
cavitation, two-phases method, vapor |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure | shangzung | OpenFOAM | 0 | November 1, 2009 13:07 |
high pressure simulation | mahi | FLUENT | 0 | November 7, 2008 01:30 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
