Projectile moving inside barrel
Hello everybody
Im starting simulation and analysis of new student project,Projectile moving inside barrel. I need to your helps for making a topic that consist all sides of this project for me and other users that need fast guide in future. i try to make it some parts that everyone can learn it step by step. Tanks a lot 1-at first how can i mesh it? |
what exactly do you want to show with that simulation? A moving mesh is not necessary as you can't model the exact movement of the bullet so I'd just go for a hybrid unstructured mesh and apply the traveling speed of the bullet as the flow velocity.
hello
tanks for your rapid response. i want to simulate moving a bullet in barrel and its exiting of barrel. at first how can i mesh it for moving bullet in barrel?(at all how we can run the bullet in barrel?) then where i should put initial pressure or velocity? TNX a Lot |
the setup for dynamic mesh, boundry condition and the parameteres are important for this simulation, at the first try you can mesh the barrel by quad and interval size of 1 and you can use inviscid model because its a high velocity problem and boundry layer is not important |
