2-D double wedge in Hypersonic flow
Old   May 2, 2014, 03:30
Exclamation 2-D double wedge in Hypersonic flow
Subhasree
Subhasree is on a distinguished road
I am modeling a 2-D wedge in hyper-sonic flow having the following free-stream conditions:
Mach no-9.59
Temperature-185.6k
Pressure-36.5Pa
I have used the following setup in fluent post:
Desity based
fluid-Ideal gas
standard initialization from farfield
I tried running the 1000 iterations initially...in which the continuity and energy equations are hardly changing while the x velocity is having a negative slope(convergence), the y velocity is having a positive slope(divergence)..i having tried reducing the cfl value...it is showing the same trend as I increase the number of Iteration...plz sugest how should I proceed
Subhasree is offline   Reply With Quote
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Hypersonic flow over double wedge marilyn FLUENT 7 April 20, 2013 14:26
Hypersonic flow over a wedge Ravenn FLUENT 6 March 7, 2013 07:12
Errorneous velocity near walls while using wedge type BC for axisymmetric flow diwakaranant OpenFOAM Running, Solving & CFD 0 February 9, 2013 00:41
Hypersonic flow scramjet ishaninair OpenFOAM Running, Solving & CFD 0 March 10, 2011 07:45
