Displacement and momentum thickness around Naca 0012 in a Transonic Flow
Like Tree1Likes
  • 1 Post By moh.sob
Old   June 22, 2013, 11:32
Default Displacement and momentum thickness around Naca 0012 in a Transonic Flow
Mohammad Sobhani
moh.sob is on a distinguished road
Hi everybody !
I'm simulating flow around a Naca 0012 airfoil with angle of attack 1.25 (degree) and farfield mach number 0.8. The results for displacement thickness and momentum thickness are shown in 2 graphs in following links.
http://inspic.com/4412C0D6
http://inspic.com/42B9FFCD
In all field, both of thickness are negative. Are they correct ?
moh.sob is offline   Reply With Quote
Old   June 23, 2013, 04:28
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
how did you calculate momentum and displacement thickness?
Far is offline   Reply With Quote
Old   June 23, 2013, 07:43
Mohammad Sobhani
I've created some lines normal to airfoil and then export x-velocity & y-velocity on them. After that with a matlab code, I projected x-velocity & y-velocity on 2 directions: parallel to surface and normal to surface in each point. finally with an integration, i calculated displacements.
displacement thickness = int[ 1 - rho * u / rho_inf / u_inf, 0 , inf ]
momentum thickness = int[ rho/rho_inf * u / u_inf *( 1 - u/ u_inf),
0 , inf ]
mm.abdollahzadeh likes this.
Old   May 6, 2014, 16:43
Abhi
abhinav.abhi19 is on a distinguished road
Your post is very interesting. I am working on a similar 3D problem and having hard time in getting MOmentum and displacement thickness. I appreciate if you can post the matlab script. I know hoe to create lines and get x and y velocity data from Fluent.
Thanks
abhinav.abhi19 is offline   Reply With Quote
displacement thickness, fluent, momentum thickness, naca 0012, transonid
Momentum and displacement thickness: du/dy calculation Josh CFX 13 October 27, 2013 14:38
general momentum source/hydraulic pressure jump/positive displacement machine ckleanth CFX 10 August 25, 2012 06:23
Expression with time function kestasposkus CFX 28 July 24, 2011 06:47
Displacement and momentum thickness ganesh FLUENT 1 April 15, 2011 10:47
Calculating displacement and momentum thickness from Fluent VSAndroid Main CFD Forum 0 April 14, 2011 13:45
