May 8, 2014, 11:54 |
open water flow
Abdalla
Rep Power: 12 |
Hi guys,
i have to simulate the water flow through an open bowl, were carbon fiber is beeing washed. Anyway, I successfully set a fluid domain and let the water flow with different temperatures and velocities. It looks like this: (Symmetry view) Fluiddomain: 3_Solid_Water_End.jpg Temp: temp.jpg An interaction with the atmosphere is not given. Fluent declaired the top surface of the fluiddomain as a wall. How do I fix this, so the water hight is not blocked by the "wall"? should I for example put a second fluid domain for air and handle the problem as multiphase? thank you |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
Problems with BCs in muliphase flow with water falling from a reservoir | Paul_l | FLUENT | 2 | March 11, 2011 04:59 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
