June 3, 2014, 03:01 |
two phase separation
ali91
Rep Power: 11 |
Currently, I am doing Fluent simulation regarding to the two phase separation at tee pipe. Below are my input parameters air velocity = 27.432 m/s water velocity = 0.02339 m/s volume fraction of water = 0.00085 flow rate weighing at side arm = 0.3 flow rate weighing at run arm = 0.7 In the result, the % of gas going into the side arm is approximately accurate but the % of liquid going into the side arm is inaccurate and its value is the same as % of gas going into side arm. Same problem is observed when I am trying to manipulate the flow rate weighing of both side and run arm. Maybe the amount of water is too small. Any idea on this problem ??? thanks in advance |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Problem with phase separation in t-junction | estenmark | FLUENT | 2 | June 3, 2014 20:18 |
Tutorial Phase separation FLUENT (HELP) | sincity | FLUENT | 6 | July 20, 2011 03:25 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
