June 11, 2014, 08:42 |
Checking the Center of Gravity
ahmady.a
Rep Power: 12 |
hi
need some help regarding specifying Center of Gravity of dynamic zone in fluent(rigid body motion) i use update button in dynamic mesh panel but Value is always zero. |
June 27, 2014, 03:37 |
sreenivas devaraju
Rep Power: 11 |
Hi ahmadi,
I am doing a CFD analysis of an oil pump using 2.5D re-meshing approach in Ansys 15. The oil pump is of lobe (inner and outer rotor) type. I have the UDF (user defined function) ready where I have defined the RPM of the rotors. In Ansys, in Design modeller, the user can select any body/surface/profile and click on "Tools>Analysis Tools>Mass Properties. This will display the centroid of the selected feature (defined by x, y and z co-ordinates) with respect to global co-ordinate system. In my case, below is what I did, 1. In Fluent where we define the dynamic mesh zone under "Dynamic mesh" 2. Click on "create/edit" button in "Dynamic mesh zone" window. 3. Select the type as rigid body. 4. In the small selection window (where there is arrow mark to scroll down). Select the appropriate zone defined in UDF (i.e., inner or outer rotor). This selection is made in the "Geometry definition" tab. 5. In the same "Geometry definition", define the centroid by entering the x, y and z values. (I did the same for inner and outer rotors) 6. The contact interface of the rotors fluid volume should be selected as deforming type and is defined by selecting the plane option in the "Geometry definition"tab. In "Meshing options" smoothing and remeshing is ticked. 7. The bottom interface of the rotors fluid volume (non contact one) is defined as per step 6, except that only smoothing option is selected for this. |
June 27, 2014, 04:56 |
sreenivas devaraju
Rep Power: 11 |
The above method has been used in solving one of the problems. But, I too have a doubt defining x, y and z co-ordinates for dynamic mesh zone. I mean, the method above is correct as it has solved a problem. In another problem, if I use the same method, the rotation of the rotors is not proper when I check in "display zone motion". I guess it is the x, y and z co-ordinates not defined properly is causing the problem.
Anyone, please clearly explain how to define dynamic zones using options available in Fluent. |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 05:41 |
Help%7e%7einstall openfoam13 on fc5%7e%7e | aderliner | OpenFOAM Installation | 2 | September 11, 2006 07:24 |
Gerris software installation | mer | Main CFD Forum | 2 | November 12, 2005 08:50 |
