[Sponsors] | |||||
Rep Power: 0 ![]() |
Hi folks,
i am currently simulating the flow through an L-shaped pipe. The fluid enters at the horizontal inlet at a radius r_0 and leaves the pipe at the vertical outlet at a radius r_5 which is bigger than r_0. The x-axis (horizontal axis) of the pipe is tilted by 11° around the radial axis, so it doesn't match the global/absolute x-axis. I start my calculations with a no rotation around the global x-axis. I tried: Pressure Inlet: Total pressure and gauge pressure given, for the first iterations no direction vector is specified Pressure Outlet: A pressure smaller than the total pressure at the inlet is assumed, no backflow direction is specified I use a pressure based solver and run time-steady calculations. For turbulence i use the k-e modell with enhanced wall functions. For the solution methods, i picked the SIMPLE scheme, and use second-order upwind for all discretization schemes. I found out that a hybrid solution initialization works best and i tried very low URF (<0.1) and moderate URF (~0.3) for my calculations. Problem The problem is, that i always got backflow at the pressure outlet, so we attached a cylindrical volume with diameter and height in the dimension of 20 times the pipe radius. This seems to fix the backflow at the outlet for me. BUT: i still get backflow at my inlet, which according to my supervisor cannot be. So we made a compromise and set the direction at the inlet to normal to boundary at all times. For a rotational speed of 0rpm, this works fine, but the moment i raise the rpm (and also the total pressure), we experience backflow which doesn't go away (after more than 5000 iterations). This happens for incompressible and compressible flow. Do you guys have any ideas? Thank you in advance! Best Regards Christian |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| setting the correct format of nonuniform List<vector> for inlet in 0 Folder | cfdonline2mohsen | OpenFOAM Running, Solving & CFD | 8 | July 18, 2019 09:03 |
| Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 15:39 |
| Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 12:31 |
| Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
| Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 08:37 |
